Sequential Shifting... 6 speed
see this site... Developed for Alfa 4cyl. Should be somewhat applicable to Elan, no?
http://www.alfaholics.com/2012/10/alfah ... version-3/
- foggy
Quaife designed this gearbox to be installed where their various versions of the T-9 had been used previously. Therefore they put the gear lever in the same spot as with the standard T-9 box, so it won't directly fit an Elan. Of course if you want to add paddle switches to your Chapman-signature steering wheel...
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
Elan +2S (1971)
Elite S2 (1962)
Maybe this should be in the mods section...
I don't know if it couples nicely with a Lotus Twin Cam but it should fit on my car easily (alfa twincam).
However, as mentionned above by CBUEB1771, flappy paddles push a bit the boundaries of a classic car... but if need is, why not?
Lotus Seven 1965 S2
can be seen here, if not on the road...
Etienne 7 - Second Gear
If it doesn't mate to the Elan bellhousing, Quaife will happily either modify your housing or make an adapter plate, so this won't be a problem..
- stevebroad
Users browsing this forum: gjz30075 and 16 guests
