S3 4 speed box
PostPost by: jmp » Thu Aug 09, 2012 10:23 pm
Does anyone know offhand how much oil the 4 speed gearboxes take. I believe it is EP 90 oil but I can't find out how much it takes to fill it from empty.
Thanks in Advance, John
jmp
PostPost by: europatek » Thu Aug 09, 2012 11:07 pm
The filler plug is the level. Fill the box until the oil just runs out and you're done. Same for the diff.
europatek
PostPost by: UAB807F » Fri Aug 10, 2012 7:07 am
The chassis plate on my car says EP80 and that's what I've always used. I think it's about a litre you need from empty although I usually buy 2. (mine leaks, so it won't go to waste :cry: )
UAB807F
PostPost by: ardee_selby » Fri Aug 10, 2012 8:24 am
elan-f14/speed-box-t25878.html
Just a cross reference (between duplicated posts)
ardee_selby
