Where do I get a 10 tooth Bendix starter gear in the Uk?
Just pulled the high torque starter off an s3 elan and found the 9 tooth bendix worn at the end. I've red an earlier thread about 10 teeth bendix gears and thought I would go with this. Where do you buy these from in the Uk please? Secondly is it worth insert a length of studding instead of the top bolt. Any pro's and cons. Just seems that it would be easier to replace and line up if the top connection sat on a stud.
Thanks in advance,
Thanks in advance,
- jmp
http://www.ebay.co.uk/itm/10-Tooth-Star ... 483wt_1037
On Ebay ?14.50
http://www.ebay.co.uk/itm/M35J-M35G-INE ... 2774wt_905
Or ?16.60 + ?4 P+P
On Ebay ?14.50
Or ?16.60 + ?4 P+P
Jason1 - Coveted Fifth Gear
Thanks Jason, but it's the high torque one as listed here under RAC500L:
http://www.racemettleltd.co.uk/l.html
They seem to be imported from Denmark
- jmp
