Gearbox breather
How important is the position of the gearbox breather bolt? Mine is in the top right hole on the extension cover plate not the bottom left as I believe it should be. With the oil filled correctly to level a significant amount of oil is blown out of the breather - enough to run down the box and onto the exhaust. I'd just move the bolt but I think I'll have to remove the gearbox mount and drop the back of the gearbox a bit to get the bolt into the rear hole, which i'd rather not do if it isn't going to make any difference. Any thoughts?
Vernon
Vernon
Elan S2 26/5614
Alfa Romeo Alfetta Berlina 1974
Westfield 7SE
Westfield 7SE
- quaybook
Vernon,
The breather was mentioned in this thread wrt a possible contributor to oil leaks:
post153288.html?hilit= breather#p153288
I had found "Ensure that the rear cover is correctly fitted (i.e. vent hole to the rear)"
From: http://www.lotuselan.net/publish/lsb_ge ... ding.shtml
Cheers - Richard
Cheers - Richard
- ardee_selby
