Engine/gearbox mountings
When I bolt up my engine mounts, the gearlever is offset about 1/2" to the left and the gearbox carrier bracket doesnt line up at all with the bolt holes in the new ( well it was about 10 years ago) Lotus LR chassis, the bracket is about 1" forward of the hole positions.
I can line up the engine etc fore and aft by adding a washer under each right hand engine mounting to swing it anticlockwise a bit but that still leaves the gearbox bracket way out. Has anyone else encountered this? and any suggestions welcome.
thanks
rod
thanks
rod
rodlittle - Third Gear
Are there spacers on the Exhaust side engine mount to block? They should be 1.125 inch with a 1500 engine block height, all Elans should have them. engine mounts are different for the Weber cylinder head engines also and can only be mounted in the failsafe position.
elan-f14/engine-mounts-t16245.html
Hi Rod,
Probably a dumb question but have you got the gearbox mount crossmember the right way round ?
S4 DHC
S4 DHC
- oldelanman
Tailshaft housing and early gearbox mounts
elan-f15/early-late-gearbox-tailshaft-housings-and-mounts-t19281.html
elan-f14/late-and-early-gearbox-mounts-t16575.html
Crossmembers
elan-mods-f31/worthwhile-mod-t23286.html
Crossmembers
Thanks for all the pictures pissant, I have the gearbox with the lump cast on which fits into the support rubber, but I had assumed that this was the original gearbox, maybe not, I will check the numbers on the casting tomorrow. Still leaves me with the original problem but I can easily relocate the mounting holes in the gearbox bracket.
As am aside, how much of the propshaft bearing surface is there normally exposed, I have about an inch between the uv joint and the tailhousing see pic below
actually its a bit less than that as the tailshaft was unsupported in the [ic
Looks about the same as My Syyder chassis.
on the Lotus replacement chassis there are 8 bolt holes, for 4 or 5 speed gearbox mountings!!
there are also 2 round spacers between the metal mount and the rubber mount!!
Alan B
Alan B
- alan.barker
Now Im really confused, If I centre the gearstick between the chassis fork then the mounting bolt for the rubber gearbox mounting is about 1/2" off centre and so of course the rest of the gearbox mounting is offset and the holes in the chassis are way off. Maybe the gearbox is supposed to be offset to the left ? thats the only way it all fits together( well nearly)
anyone else noticed this or is mine weird
Thanks for any suggestions
rod
rod
