Matching a Lotus 4 speed bell housing to T9 gearbox
PostPost by: rjaxe » Sun Mar 06, 2011 5:40 pm
Can any member detail what is involved please.
rjaxe
PostPost by: alaric » Sun Mar 06, 2011 6:06 pm
Hi. I thought you had to get a special bell housing but happy to be corrected on that. Burton power sell bellhousings that'll do the job; this appears to be the one that you're looking for: http://www.burtonpower.com/bh3.html
Regards.
Sean.
alaric
PostPost by: types26/36 » Sun Mar 06, 2011 6:20 pm
alaric wrote: Burton power sell bellhousings that'll do the job; this appears to be the one that you're looking for: http://www.burtonpower.com/bh3.html
With that Burton one I think you would have to convert to cable operated clutch......I believe this is the one you want to retain the hydralic clutch http://cgi.ebay.co.uk/ZF-ROCKET-ALLOY-B ... 3a4ee8a93d
types26/36
PostPost by: kstrutt11 » Mon Mar 07, 2011 1:23 pm
I used A Left Hand Drive tye 9 bell housing with the clutch cable abutment ground off (puts starter in right place) and then machined a apacer up to mount a Concentric slave cylinder.
Kevin
kstrutt11
PostPost by: rjaxe » Tue Mar 08, 2011 5:29 pm
Thanks for all the responses, very helpful as usual. I am surmising that to use a 2000e bell housing would require a spacer plate to accomodate the different housing attachments. Has anyone succeeded with this approach?
rjaxe
PostPost by: alaric » Tue Mar 08, 2011 7:21 pm
additional requirements eh...
My type 9 conversion has a concentric hydraulic clutch slave cylinder, with the hydraulic pipe going in through a drilling in the bell housing. Here are some pics:
T9 from above.jpg and
T9
T9 inside bell housing.jpg and
Showing the slave cylinder
Sean.
alaric
PostPost by: ncm » Fri Mar 11, 2011 4:16 pm
Is this what you're after?http://www.dalek.pwp.blueyonder.co.uk/105speed/Milton.pdf
Brian.
PostPost by: rjaxe » Fri Mar 11, 2011 7:07 pm
Many thanks to all for the comments, the T9 is now in bits on the bench (having mopped up all the oil that hid itself until I split the casings) ready for its inspection.
rjaxe
