UK Supplier for Trunnions, stub shafts, bearings etc.
Hi All
I'm just about to start rebuilding my front suspension and want to replace the 'consumable' parts. I'm also fitting new (bolt on) hubs to replace the knock ons, so will need replacement stub axles. I'll be keeping my spare uprights with all the knock on parts fitted should I decide to return to knock ons at some stage, so please don't come round and lynch me quite yet
Can somebody recommend the best supplier for quality parts - I guess I can go to the Triumph suppliers as well as Lotus for these bits.
Thanks in advance
Wyn
Thanks in advance
Wyn
- lsdweb
The alloy ones with Canley Classics (here - http://www.canleyclassics.com/?xhtml=xh ... roduct.xsl) look good!
- lsdweb
I went for alloy hubs but I'm not sure I would do it again. The problem is that the differential expansion of alloy vs steel gives two problems:
- you need a greater cold end-float on the bearing to allow the hub to expand;
- the bearing races become loose in the hub when it heats up.
There was a thread about it here:
elan-f15/front-hub-bearing-failure-t19304.html
Just my experience, I'm sure there are other opinions.
Paddy
Paddy
1963 Elan S1
paddy - Coveted Fifth Gear
Thanks Paddy
I've seen that post - I think I've gone through the entire archive
The car is a sprint and hillclimb car so it won't be generating the heat that an out and out racer would but I'll still need to be careful with end float. It seems from my searches that the cast GT6 hubs aren't readily available.
Wyn
Wyn
- lsdweb
lsdweb wrote:It seems from my searches that the cast GT6 hubs aren't readily available.
I got some secondhand ones from a Triumph breaker - I think they're not too hard to get but you're probably right that you can't get them new.
Paddy
1963 Elan S1
