S2 Gear Shift / Gearbox Rattle
My Elan gearbox shifter rattles when driving the car in third gear. Advice on how to fix it would be appreciated. I plan to pull the motor and trans this weekend for maintenance.
Eric
Eric
- SpeedModel
Have you tried driving it without the shift boot, to discern the source of the rattle (e.g. is the shift rail worn, or the ball of the shift lever in the socket)?
Jim
Temporarily Elan-less
summerinmaine - Fourth Gear
I think this rattle/buzz is the reason Lotus introduced the "anti-sizzle" lever in the later Elans, with a rubber bushing to isolate the shift lever from the mechanism. Or it may just be wear.
Andrew Bodge
'66 Elan S2 26/4869
'66 Elan S2 26/4869
RotoFlexible - Fourth Gear
Is there a detent adjustment on these gearboxes?
- SpeedModel
I had, what was called a buzz, not a rattle, in third and later in other gears. The plastic shift cap was so loose that I could not get it into reverse. I solved it by tightening the plastic dome cap down. It has happened twice over the last 5 years. The second time I knew what to do. I was thinking of a new aluminum cap that might hold up better than the plastic ones. I was worried I had a real problem but was happy for a simple solution. The transmission works great.
Sarto
Sarto
lotus elan 1966 S3 FHC
36/5785
LHD
36/5785
LHD
mac5777 - Fourth Gear
mac5777 wrote:I had, what was called a buzz, not a rattle, in third and later in other gears. The plastic shift cap was so loose that I could not get it into reverse. I solved it by tightening the plastic dome cap down. It has happened twice over the last 5 years. The second time I knew what to do. I was thinking of a new aluminum cap that might hold up better than the plastic ones. I was worried I had a real problem but was happy for a simple solution. The transmission works great.
Sarto
Even though my plastic cap is just fine, I want to get one of those because it is sooooooo beautiful!!
Jim
