Gearbox swop?
The normal needle rollers I use have a nylon ring at one end inside the outer case, this acts as a seal (of sorts). Position this seal to the clutch side and it helps prevent water, dirt and dust getting into the pilot bearing. As other have said its a blind hole so only need the seal at one end
Progress report!
Anyone else having as much fun as I am?? Brilliant!
Alex...
Alex...
Alex Black.
Now Sprintless!!
Now Sprintless!!
Sorry. I would forget my head if it was not welded on....
This little sketch is courtesy of Andrew. It shows the dimensions etc of the bearing holder for the 5 speed gearbox input shaft pilot (spigot) bearing. The bearing number is the INA number written on the pdf also. Hope this is helpfull to you.. I am about to start making one. The bearing is easy to obtain from bearing suppliers. I had one in my car stock. Much to my amazement.
Many thanks Andrew..
Alex
Alex
- Attachments
- Lotus spigot carrier.pdf
- (168.1 KiB) Downloaded 466 times
Alex Black.
Now Sprintless!!
Now Sprintless!!
L plate noted just above the engine hoist in photo 2 Alex!
Glad you're having fun.
Visit www.lotuselansprint.com
trw99 - Coveted Fifth Gear
The braking strain of the 10mm dia Polyprop' rope I used? Well no doubt you will be surprised to learn that it is 1425 KG Bill. Check it out!
http://www.unionindustries.co.uk/tradin ... pylene.htm
Thanks Tim..... Not used for some time...
Alex Black.
Now Sprintless!!
Now Sprintless!!
Is the "Lotus" cover over the front of the car magnetic too? I find that they don't stay in place too well.
Pete.
http://www.petetaylor.org.uk
Pete.
Sorry Paddy.. I edited the post. I was a bit hard on Bill so took it out..
The L's were last used to teach daughter.... The front L went awol...
Thanks Tim...
Alex...
Thanks Tim...
Alex...
Alex Black.
Now Sprintless!!
Now Sprintless!!
Stays in Place good Pete. The std item from C/L supplier. Can't remember the name... I am to buy another soon.
Why the ?
Ab..
Why the ?
Ab..
Alex Black.
Now Sprintless!!
Now Sprintless!!
Re.the sketch of the carrier,shouldn't the internal diameter be 0.824?
The bearing is metric at 21.00 O/D x 15 long.
The one I have in my hand is INA (F-331262) and the O/D measures an average of 0.828".
So allowing 2 thou for interferance, and in this case, 0.826" is what I would use, John.
BTW the INA bearing has a nitrile seal at one end.
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
bcmc33 - Coveted Fifth Gear
Sorry Brian,I thought it would be Imperial at 0.825"
Does this mean you don't need a gasket?
- mikealdren
What's the matter? Don't you trust me anymore? EErrr ..I measured it. Andrew sketched it!
I am just making the internal bore a good but not too tight int' fit to the bearing. Just a light pressure to fit. Not started yet but I will get to it soon...
The release bearing is smaller I/d for the 4 than the 5. To fit the 5 onto the 4 'holder' it need a little sleeve turning up. Which I think means that the std 4 speed lever arm will fit without any mods? Is this correct?
Sue M has also told me that the speedo cables are the same. She only stocks 1 type. ''Fits all Elans''.
Gearbox build is underway. Clutch bits will be with me mid December. Gearbox will be out of the car and on the 'bench' by this weekend.
Alex Black.
Now Sprintless!!
Now Sprintless!!
