Heavy Clunk when Setting Off
This has only just developed.
When I an stationary in my +2 and take off for a fairly fast start, there is a heavy clunk from underneath the car - enough for me to feel the jolt through the seat. It does not happen at any other time, including doing the same thing in reverse. The car is otherwise going very well with no transmission noises to speak of.
If you pull away more gently there is no clunk.
I have tried:
Checking the wheels for tightness - OK
Visual inspection of all the suspension brackets on the chassis - no cracking, slack bolts or missing bolts.
Exhaust checked for tightness - OK
Engine and gearbox levered against mountings - no clunking and reasonably stiff.
Torque rods on diff - OK.
Tried levering diff upwards - right hand diff mounting (as viewed from the back) looks to have too much movement in it - 2mm with not much levering - no clunking though.
CV bolts checked - OK
Running out of things to try.
Could it be something internal, or something not on the list above?
When you accererate, does that right hand diff mounting go into compression?
Any help will be much appreciated.
Dave Chapman
I have tried:
Dave Chapman
- david.g.chapman
Thanks for your suggestions. I tried the 3/4 gear trick but could not get any knocking. This would work if the knock happened at very slow take-offs. Prop-shaft looks OK.
I have just removed the fuel tank to look at the offside (UK) upper diff mount. The metal plate at the top of the mount is broken, so the mount has virtually no damping effect under compression! It just holds the diff up.
I now believe that under acceleration it is this side that gets compressed, and the mounting bolt makes an attempt to punch through the fuel tank - not good.
I have ordered two from Spyder Engineering (SM is out of stock).
Knowing my luck this is not causing the noise, but I will post again is something else ends up being the cause - and I find it!
Dave.
Dave.
- david.g.chapman
I fitted new Spyder top diff mounts to my Sprint during a chassis change. Four months later I chucked out these trashed items and got a pair of heavy duty ones from Tony Thompson. Still fine after five years.
All rubber parts seem to be rubbish these days, not just Rotoflexes.
Pete.
http://www.petetaylor.org.uk
Pete.
Thanks for the info, Peter.
As it was 5 years ago, things may have improved - I quizzed Spyder on the phone about rubber quaility and they assured me they were the best on the market - but you never can tell with that line of questioning.
I will still give them a good examination on receipt, though. I think Rohan had a way of taking some stress out of the rubber - I will search the posts.
(edited) - Found the post. Rohan suggested using a large thick penny washer top and bottom to spread the load across the centre tube and the surface of the rubber - I will look into it.
Dave.
Dave.
- david.g.chapman
I had exactly the same noise and it turned out to be the same failure, rear tab of rh diff mount sheared off, I made a reinforcing plate to go over the top of the new mount, hopefully this will help long term durability, the rubber was perfect though on both sides (they were in there when I bought the car 13 years ago, it did have large washers top and bottom.
Good news is it Fixed the problem.
- kstrutt11
Kstrutt,
Do you have more details on your reinforcing plate? Where does it fit onto the mounts?
Looking at another of Rohan's posts, he describes the top washer as clearing the area just under the bolt head (or nut if the bolts are the other way up) to spread the load - so it is not a simple washer - maybe a washer with a larger centre hole under the existing washer - or something conical.
I really must get the old mounts out and have a proper look - but I have a stinking cold and don't feel like doing anything at the moment . Tomorrow is another day.
Dave.
Dave.
- david.g.chapman
Thanks, Kevin. I've got the idea.
I now have the Spyder mounts, and have attached a picture of my old mount - with a snapped ear - on the right, and the "new" Spyder mount on the left.
The two mounts look identical, down to the coding on the rubber and the general finish. Maybe Spyder have got a hold of some genuine Lotus bits.
As the old mount lasted 25000 + miles with my CV joints, I am happy to fit them with either Kevin's brace, or a conical washer that goes over the rubber cone at the top.
Dave.
Dave.
- david.g.chapman
When I stripped my plus2 down a few years ago I found exactly what you have. Both of the mounts had been replaced by the po and looked in very good condition, so good in fact that I intially thought that the po had only just fitted them and must have done something wrong. Fairly confident that was not the case now as there have been a few threads covering this previously.
Chris.
Chris.
tcsoar - Third Gear
That's it Alan!
Now where is that 3mm thick plate ali I had?
Dave.
Dave.
- david.g.chapman
Everything now re-assembled. I have tried out the car and the clunk is gone.
Many thanks to you all.
Dave.
Dave.
- david.g.chapman
