Gearbox oil filling problems over
Why didn't I buy one of these years ago...
http://www.performance-oils.co.uk/acata ... nsers.html
"General purpose fluid dispenser" - 9.99GBP, 15 Quid with Tax & delivery. Worth every penny - easy to control the flow into the gearbox filler hole, with almost no mess. I'm sure everybody else has already got one, but why did nobody tell me earlier?!
Jeremy
Jeremy
JJDraper - Coveted Fifth Gear
Till I scrolled down I thought you were talking about the rotary barrel pump. 27L /min - that would fill the gearbox pretty quickly. A little difficult to get under the car though
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
- 69S4
I've got a plastic pump/hose/nozzle combo that threads into the standard gear oil bottles we get over here. It came with a two bottle purchase, and is one of the handiest freebies I've ever used.
Check around and see if anyone is running a similar promotion, though it's been ages since I got mine.
Jim
Temporarily Elan-less
summerinmaine - Fourth Gear
I am about to do this job and was thinking about getting one of these from Harbor Freight.
http://www.harborfreight.com/fluid-siph ... 93290.html
Dan
Dan
Why don't you just remove the shift lever and pour the oil in there. If you wish, you can remove the side level plug and stop adding oil when it reaches that level. I've done this to fill my Elans for years. Also works on my '86 Toyota AE86 GTS coupe. If filling from empty, you can simply add the amount the shop manual says is the capacity.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
Oh, I should mention, this won't work on a Mk1 Cortina with the shifter extension, but it would if the whole shifter extension is removed. Roger
'67 Elan S3 SS DHC
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
collins_dan wrote:I am about to do this job and was thinking about getting one of these from Harbor Freight.
Dan
I have one of those. Never could get mine to work worth a dam.
YMMV
Jim
The other options I was considering are:
http://www.harborfreight.com/multi-use- ... 66418.html
http://www.westmarine.com/webapp/wcs/st ... sNum=11109
What was the problem with getting the siphon pump to work?
Dan
Dan
collins_dan wrote:The other options I was considering are:
Dan
The pumps from West Marine are like mine, except that mine has a 24" hose attached to the "faucet" spout. And the intake hose is sized to fit a standard gear oil container.
The siphon pump would always have a lot of backwash (probably cheap-o valve) and always break suction. Didn't seem to matter what viscosity fluid I was pumping, it would neither pump efficiently nor allow any extended siphoning.
I would go for either of the two pumps you just posted rather than try another siphon pump.
Jim
We did this a while back here:
elan-f15/filling-the-tranny-t20729.html
there are a couple of suggestions there
regards
regards
_________________
1969 ELAN PLUS 2S
1998 CATERHAM 7 SUPERSPORT
1969 ELAN PLUS 2S
- elan_fan
SOME YEARS AGO WE SHARED A GARAGE -THERE WERE 4 OF US ---one of the guys discovered that if you emptied a fire extinguisher-added hypoid and charged the bottle with air you could fill a tranny right quick -----we all lived in fear of fire in the shop for many years after ----ed
