Crankshaft spigot bearing
Morning!
Can anybody advise me on how to remove the spigot bearing from the end of the crank, before I take it to the local engine machine shop? Crank currently on my workbench.
I have tried the grease and clutch alignment tool method suggested by Miles Wilkins without success.
Martin B
Martin B
- martinbrowning
Martin,
They are surpisingly easy to remove simply by levering out.
Remove the seal which will leave a nice ledge for a screwdriver to locate.
It may be easier to use two screwdrivers to lever at 180 degrees.
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
bcmc33 - Coveted Fifth Gear
martinbrowning wrote:Morning!
Martin B
Why not just let the machine shop pop it off?
You are going to replace it before reassembly, right?
Jim
Temporarily Elan-less
summerinmaine - Fourth Gear
Users browsing this forum: ericbushby, Tmac897 and 20 guests
