Gearbox mount spacers
PostPost by: graham » Thu Jun 10, 2010 10:19 am
Can anyone give me the size of the spacers to mount to chassis as all I have is container with various size spacers and I dont know which is which ?
Graham
graham
PostPost by: bcmc33 » Thu Jun 10, 2010 12:22 pm
Assuming a 4 speed box - the spacers are 1.125" O/D x 0.4375" thick.
If it's a Lotus 5 speed box you don't need spacers.
Brian Clarke
(1972 Sprint 5 EFI)
bcmc33
PostPost by: CBUEB1771 » Thu Jun 10, 2010 1:34 pm
graham wrote:Can anyone give me the size of the spacers to mount to chassis as all I have is container with various size spacers and I dont know which is which ?
Graham
I presume you mean the spacers that go between the gearbox mount and removable cross member. If so Brian is correct. There are no spacers between the chassis and the crossmember.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
CBUEB1771
PostPost by: jono » Thu Jun 10, 2010 2:48 pm
...by coincidence I will be fitting my engine and 4 speed into a refurbished Spyder chassis this evening.
Where do these spacers go as they are something I had not realised were required (bough the car in bits!) :shock:
Are they perhaps not required on a Spyder chassis?
PostPost by: bcmc33 » Thu Jun 10, 2010 5:06 pm
jono wrote:...by coincidence I will be fitting my engine and 4 speed into a refurbished Spyder chassis this evening.
Jon,
Do you have the Spyder bracket or the Lotus bracket?
The Lotus bracket needs spacers to raise the gearbox to the correct height.
The Spyder bracket is taller and is the correct height.
Brian Clarke
(1972 Sprint 5 EFI)
bcmc33
PostPost by: jono » Thu Jun 10, 2010 9:41 pm
Brian - many thanks for that, I have the Spyder bracket so I guess I'm okay :D
Jono
