Sticking in reverse
Sticking in reverse so i lift with one hand and whack with the other, this does not feel right but Ive got to drive my elan... Is there an easy tweak??
>.....ELAN 1969 S4 SE COUPE.....<
>...SEE YOU ON THE FLIP SIDE...<
Crusty - Second Gear
Crusty,
I dont really follow your post but have you made sure the plastic (sometimes metal) cap that holds the gear lever in is screwed down tight?
By the way .....welcome to the forum
types26/36/74 wrote:Crusty,
thank you Brian for the reply and the welcome, plastic nut down tight, 1st 2nd 3rd 4th switch in nice nice reverce goes in dont like to lift back out and back to N.
Loving my elan loves the road so much more than my now moved on elise not sure i want to track this car though. wot a drive ticks a lot of boxes
Crusty,
Not sure if this will help, but I had a similar problem, with the gear lever jamming between reverse and the 1/2 shift rod. What was happening was the gear lever was rising up too far when pulled upward. The cure was to make a spacer slipped onto the shift lever approximatey .035 thick to prevent the lever from being pulled up to far. Never had another problem.
Rob Walker
26-4889
Rob Walker
26-4889
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
prezoom wrote:Crusty,
Rob Walker
26-4889
Thanks Rob for the reply
Is the paper gasket installed under the plastic dome? Without the gasket the dome can be screwed down too far such that the lower end of the gear lever will start too foul the selector rods and cause difficult motion. Some people have had to use two of the paper gaskets.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
Elan +2S (1971)
Elite S2 (1962)
CBUEB1771 wrote:types26/36/74 wrote:Crusty,
Thanks Russ
Now I have put a few miles on the car reverse is fine, I ve got a self healing Elan!!
ps i am loving it.
whos going to Le Mans?
ps i am loving it.
