Input shaft bearing .Grease?
Hi. I have just started the engine rebuild ,its all gone well.I started to fit the Flywheel and I thought check first .
I would be grateful if someone could give me advice .The crank has a needle roller bearing fitted to take the input shaft .It looks like clean grease has been used .
Qu ---- What type of grease do I use and how much do I apply.
Thanks in anticipation. John.
- john.houston
I just use a smear of black Moly Grease (CV joint stuff) not too much although the pilot bearing does have a seal on it.
Thanks Brian. I'm sure the will be more questions. John.
- john.houston
Hi, John,
I'm with Brian! Black moly with a high melt point! (HMP) fits the bill well. Stays put well too.
Good advice..
Alex B....
Good advice..
Alex B....
Alex Black.
Now Sprintless!!
Now Sprintless!!
