Lotus alloy diff casing
I have a spare casing, but the diff ears are elongated.
Is there a successful repair for this problem, or even an improvement ?
Say perhaps, some kind of steel spacer/washer arrangement ?
Grasping at straws !
Stuart.
Stuart.
- stuartgb100
I had one repaired with some steel bushes as the holes were elongated, it was fine then a while later a CV adapter let go and broke the ear off the ear was welded and its seems fine now although I use the Sprint bracing bracket on it.
Thanks Brian.
Time to find a recommended local machine shop.
Stuart.
Stuart.
- stuartgb100
