Gear Knob
PostPost by: Over Steer » Tue May 13, 2008 8:50 pm
Hey all;
Does anyone know where i can pick up a wooden (walnut) gearlever knob with lotus logo on top? I'm partial to a "ball" shape rather than the slimmer type.
I've heard that the self threading type found on ebay are not suitable for the 4 speed 'box because of the lift up reverse.
Jan
1963 23B
1969 Elan + 2
1973 Europa JPS Special
2004 Prep'ed Lotus Exige
Over Steer
PostPost by: Elanintheforest » Tue May 13, 2008 9:51 pm
Sue Miller has them, with either the black badge or the yellow one, round or pear shaped.
Seems odd that the pear shaped knobs keep selling on eBay for ?80 plus, when Sue sells them for ?30ish.
PostPost by: Alex » Wed May 14, 2008 7:51 am
I've turned my own up out of ash as I couldn't find any wallnut at the time. It has a press fitted and bonded threaded insert, so works fine for reverse :D If I can get some wallnut, maybe theres a market out there waiting for me...
Sorry about the quality of the attached photo!
Alex
Alex
PostPost by: Alex » Wed May 14, 2008 7:56 am
Here it is!
Alex
PostPost by: peterako » Wed May 14, 2008 8:12 am
So true of many eBay etc. items.
Always worth calling Sue (or your favourite supplier of choice) first! :D
Peter
'73 +2S 130/5
peterako
PostPost by: Alex » Wed May 14, 2008 8:17 am
Third and final time....
Alex
PostPost by: Alex » Wed May 14, 2008 8:57 am
This might be it now!
Dash.jpg and
Alex
PostPost by: Over Steer » Wed May 14, 2008 9:14 am
Great guys, i'll give sue a ring right away.
Jan
1963 23B
1969 Elan + 2
Over Steer
PostPost by: Over Steer » Wed May 14, 2008 5:10 pm
trust my luck... sue does not have this part in stock at the mo...
so i was thinking of modifying the one shown below by removing the gate pattern (it's wrong anyway as mine is a 4 speeder) and embedding a lotus lapel pin in the top. then giving the whole thing a good layer of clear coat.
any opinions?
79f4016s.jpg and
Jan
1963 23B
1969 Elan + 2
Over Steer
PostPost by: mikealdren » Wed May 14, 2008 6:41 pm
Jan,
If you want a temporary fix, save the 5 speed knob and sell it on Ebay. I made up a knob for my 4 speed box by turning a piece of wood (I used some old applewood from a tree in the garden!) using an electric drill and a rasp.
First I drilled the mounting hole slightly undersize and screwed in a bolt to cut the correct thread. I then cut the head off the bolt and held the bolt in the drill chuck to turn the knob, it was surprisingly easy. Finish off with coarse then fine sand paper and a couple of coats of varnish and the knob was ready for use.
mikealdren
PostPost by: CBUEB1771 » Wed May 14, 2008 7:55 pm
Over Steer wrote:so i was thinking of modifying the one shown below by removing the gate pattern (it's wrong anyway as mine is a 4 speeder) and embedding a lotus lapel pin in the top. then giving the whole thing a good layer of clear coat.
I am not sure that the thread on the Lotus five speed gear lever is the same as on the Ford-based four speed. You should check that before trying to swap the emblems.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
CBUEB1771
PostPost by: billwill » Wed May 14, 2008 11:35 pm
I'm pretty sure that the gear knob that I have now, I bought ages ago in a furniture store. Its a decorative knob for a stair bannister.
PostPost by: Over Steer » Thu May 15, 2008 6:26 am
So it seems settled that i'm going to go down the "bespoke" route...
My mum's credenza is going to have to make do with a book instead of one of its legs, she's going to be thrilled about this one. :lol:
"Pass the hacksaw rodney..."
Jan
1963 23B
1969 Elan + 2
Over Steer
PostPost by: Alex » Thu May 15, 2008 7:24 am
The thread for a 4 speed is 5/16 UNF. For the one I made (so far...) on my wood lathe, I first turned down a pair of 5/16UNF nuts so there were no flats, then drilled the centre of my blank slightly under size for the ex-nuts. Then using some composite glue (I work in F1) I bonded the nuts into the blank using a bolt as a press tool. Using the same bolt again, I mounted it in my wood lathe and turned it to suit.
Before using any form of varnish, wipe it clean with acetone or similar to lift the grain, then apply a coat or two of danish oil to bring the grain out.
I need to find some wallnut blanks next...!
Alex
Alex
PostPost by: john.p.clegg » Thu May 15, 2008 10:57 am
You have a pm from someone who wants to do a straight swap
John :wink:
Next
