Will a +2 130/5 Diff/gearbox fit an S3?
PostPost by: gmzez » Fri Nov 30, 2007 9:50 am
Hi folks... Would a 130/5 late diff and a 5 speeder fit into a S3 without too much of a problem? Thanks....ED
gmzez
First Gear
First Gear
PostPost by: rgh0 » Fri Nov 30, 2007 10:52 am
You have to make up a new rear gear box mount but otherwise it should slot in nicely
PostPost by: CBUEB1771 » Fri Nov 30, 2007 1:16 pm
I think you will need to shorten the drive shaft from the donor 130/5 as well.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
CBUEB1771
PostPost by: ppnelan » Fri Nov 30, 2007 4:15 pm
Yes, you'll definitely need a shorter propshaft. Don't forget the clutch plate (different gearbox spline) and flywheel insert for the gearbox input shaft bearing.
:arrow: Matthew
ppnelan
PostPost by: elansprint » Fri Nov 30, 2007 5:22 pm
As the other posts you will need to shorten & balance prop. Dont forget to obtain the 5 speed release bearing carrier & the flywheel insert as these are unobtainable & of course fit a new clutch plate while it is out. i used the 5 speed box mount complete & redrilled it. There was an article on this in one of the magazines i may still have it if you send a PM i will forward it if i can find it
Ian
elansprint
