Elan 2 + 2 Gearlever Gaiter
Phil,
Originally they came off Rover P4's if you know anyone who has one Guess not??
Gordon
Gordon
- gordonlund
Secondary question Guys,
I always thought there was both an inner and an outer gaiter. Anybody ever seen an inner gaiter?
Would be handy to have as I've always had trouble getting a good seal with the outer. The odd bit of engine smell (hot oil) and heat sneak in under the centre console. I don't mind but herself gets a bit travle sick from the smell.
Hamish.
Hamish.
Hamish Coutts - Fourth Gear
Hamish,
There is an inner gaitor, it fits over the gear box Spherical nylon nut, a rubber inverted top hat affair with no top on it. Imagine a thin sheet of rubber the same size as the rectangular opening in the body. This has a hole the same size as the spherical nylon nut where a rubber thin wall tube is attached, a length to suit, 1/2" - 1" if I remember right, so it pushes over the nylon nut and gives you the seal you are looking for. I think you could knock one up with some rubber sheet and a tube of suitable adhesive. (eg Super glue) It is held down with some under-felt (sound proofing) and the centre console, arm rest. I had my back seat assembly out last week, only put it back yesterday, I have to remove this to get the front centre arm rest out. Next time I take it out I will photograph it for you, but not just yet. I've just finished the car for Donington having just changed the differential.
Gordon
Gordon
- gordonlund
Hamish,
Have a picture of the seal.
Gordon
Gordon
- Attachments
- It's only thin black rubber maybe 1/16" thick at the most.
- Elan box seal.JPG (2.4 KiB) Viewed 2248 times
- gordonlund
Thanks Gordon,
Mystery solved and a solution at hand. Looks like a piece of inner tube should do the trick for the flat bit and a short length of bicycle inner tube for the sleeve part. That's Saturday afternoon sorted then!
Thanks again.
Hamish.
Thanks again.
Hamish.
Gordon,
The picture also explains why there was a rectangular metal plate screwed to the body at the gear lever opening but there was nothing attached to it.
Hamish.
Hamish.
Hamish Coutts wrote:Secondary question Guys,
Hamish.
You and me both Hamish. She hates the smell and won't travel in it. Haven't seen this inner gaiter before and will cerainly investigate making one up!
- Phil W
Wow, the things I am still learning after 30 years of Plus 2 ownership. Mine has a pleated lower gaiter, identical to the upper one. The lower one is secured to the body shell by the rectangular metal piece as shown in the image supplied by Gordon. The style of gaiter shown in this image makes so much more sense. I thought mine was in original configuration. Maybe they had just run out of lower gaiters in Norwich on the day mine needed one and two were taken from the upper gaiter bin.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
Elan +2S (1971)
Elite S2 (1962)
Phil,
Whereabouts in Cheshire are you?
Cheshire Lotus Owners Group (CLOG) meets at Swettenham Arms, 1st Sunday in month, 13:30; couple of +2 experts in the gang!
Next major group outing is Gawsworth Classic Car Rally 7th May, but you can find us at Oulton Park and severial(!) pubs across Cheshire most nights of the week.
Pete.
http://members.lycos.co.uk/clog/
Pete.
I got very curious about the drawing of the seal posted by Gordon. I spent 15 minutes with the service and spare parts manuals for both the Elan and +2 last night. Sure enough, the illustration provided by Gordon is in the gearbox section of the +2 service manual. However nothing like it appears in the spares book. The spares book lists only the pleated gaiter (050 F 6000) and this is used in two locations, both secured to the body shell and the center console (essentially two nested inside one another). Therefore the configuration of my +2S matches what I see in the spares book. Does the seal shown in the service manual actually exist? I have found plenty of bad information in the service manuals, such as all of the dimensions shown in the +2 front suspension drawing actually being for the Elan.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
Elan +2S (1971)
Elite S2 (1962)
