Speedo Trip Resetting
PostPost by: pmallinson » Sun Oct 29, 2006 12:33 pm
Simple question here, how is the speedo trip odometer supposed to be reset to zero ? I cannot find any push button or turn knob anywhere obvious ?
My car is a 1973 +2S 130/5
Peter Mallinson
[email protected]
pmallinson
PostPost by: andyhodg » Sun Oct 29, 2006 2:06 pm
Peter
On my +2 (an early 1969) The trip reset is jus behind the botton edge of the dash just to the right of the speedo.
Andy
andyhodg
PostPost by: dlbarnes1 » Mon Oct 30, 2006 2:22 am
On my Sprint, there was no trip reset. I had it added when the speedo was refurbished. I wonder if that was common on the late model cars?
Dave, 72 Sprint DHC
dlbarnes1
PostPost by: ElliottN » Mon Oct 30, 2006 6:11 am
On my S4 it's same as Andy's +2 - a short, straight, sleeved cable coming straight down from speedo with a knurled knob which appears just below the bottom of the dash - you simply turn it to reset the trip odo.
Elliott - 70 S4 dhc
ElliottN
PostPost by: Sarah Ryan » Mon Oct 30, 2006 6:29 am
The same on my Sprint as Elliott described!
Sarah Ryan
First Gear
First Gear
PostPost by: pmallinson » Mon Oct 30, 2006 6:36 am
Well I have to say having own a raftof classics befor and even (unfortunately) having grown up when most of them were new the 'sleeved cable with a knurled knob' is exactly what I expected but cannot find :?
Maybe its tooked up insde the dash behind somewhere :(
More investigation needed obviously
Cheers for the info though
Peter Mallinson
[email protected]
pmallinson
PostPost by: reb53 » Mon Oct 30, 2006 7:23 am
Mine is the same as described by Elliot.
From memory it was easy to remove so you could withdraw the guts of the speedo from its casing.
Has yours fallen off at some stage ?
The hole at the bottom of the casing would be visible looking up from underneath.
Ralph.
reb53
PostPost by: RotoFlexible » Mon Oct 30, 2006 6:20 pm
The trip odo reset knob and shaft broke loose from the rest of the mechanism decades ago on my car. I still have it in a box of small parts that are no longer where they belong. It didn't look like a trivial job to replace it.
Andrew Bodge
'66 Elan S2 26/4869
RotoFlexible
PostPost by: Schrodinger » Mon Oct 30, 2006 9:15 pm
I wondered the same when I first got my Elan, after much fiddling around the back of the dash I came to the conclusion the reset 'thing' must have disappeared at some time in the past and just managed without it.
After a slight issue with gearbox oil ( :roll: ) I've just had my speedo refurbed and it's come back complete with new trip reset knob! A nice bonus!
8)
Now the challenge comes of refitting the speedo without breaking it off again...
:lol:
Schrodinger
First Gear
First Gear
PostPost by: tonycharente » Fri Jun 15, 2007 3:59 pm
Schrodinger wrote:I wondered the same when I first got my Elan, after much fiddling around the back of the dash I came to the conclusion the reset 'thing' must have disappeared at some time in the past and just managed without it.
8)
:lol:
Hello,
My speedo works just fine but I too am missing the trip odometer reset 'thing'. I was wondering (Schrodinger) if you could tell me who it was who was able, in effect, to supply you same, please. Similar info from anyone else also welcome of course!
Many thanks,
Tony
1969 Elan FHC S4 SE
tonycharente
PostPost by: elansprint71 » Fri Jun 15, 2007 4:39 pm
It would be very easy to lose the reset gizmo; if you turn it the "wrong way" just a few turns, it screws out. it requires some athletic limbo dancing under the dash to get it back in; I guess lazy DPO's might not have bothered. :roll:
PostPost by: PanoGuy » Sat Jun 16, 2012 12:33 am
After almost 27 years of my ownership, the trip odometer re-set knob has failed, I think it pulled down a bit, I never knew which way to turn it so I generally turned it one way and then the other. But I have used them almost every tank of fuel since I got my first Elan.
RotoFlexible says the repair is non-trival, but can anyone explain how it attaches and how to replace it? Both my Elans have always have had functioning trip odometers and I like them, I find them more accurate than the fuel gauge. It would be nice to have it working again.
But it does not seem to simple screw in unless I am missing something.
PanoGuy
PostPost by: TeeJay » Sat Jun 16, 2012 9:09 am
PanoGuy.
The Trip Odometer connection on the back of the Speedo, is very similar to the way the Speedo cable fixes. i.e. they are both male threads on a post. It is positioned slightly above the centre speedo cable in line with the actual trip recording and to the right (looking from the front).
Be careful of the bulb wires.
The Trip Odometer cable has an inner cable that has to fit into the hole, then the female threaded ring nut screws onto the male post. This secures the inner cable and outer cable. You can check all is well by turning the knurled nob, which will reset to zeros.
Trevor
1968 Elan +2 50/0173
PostPost by: oldelanman » Sat Jun 16, 2012 9:36 am
TeeJay wrote:The Trip Odometer connection on the back of the Speedo, is very similar to the way the Speedo cable fixes. i.e. they are both male threads on a post. It is positioned slightly above the centre speedo cable in line with the actual trip recording and to the right (looking from the front).
Mine emerges from the side of the speedo casing pointing straight down.....
Odo trip cable 001.jpg and
S4 DHC
PostPost by: PanoGuy » Sat Jun 16, 2012 1:40 pm
Mine looks like yours Roger, but I just can't figure out how it attaches and how it engages. I suppose I need to pull it out again and take a closer look. I feel some of that gentle clicking sound when I turn it, but it does not turn the odometer numbers. The manual just says remove and replace, I guess I should try again.
Doug C
PanoGuy
Next
