S4 clutch pedal
PostPost by: triumphelan » Fri May 12, 2006 7:54 am
Should I have a return spring on the clutch pedal ?
Regards John 1969S4DHC
triumphelan
PostPost by: steveww » Fri May 12, 2006 8:29 am
My S4 has one, it goes through a hole just above where the cylinder push rod attaches to the pedal arm, back to the pedal box.
steveww
PostPost by: nebogipfel » Fri May 12, 2006 12:02 pm
Yes it's not the most elegant arrangement but it should be there.
nebogipfel
PostPost by: triumphelan » Sat May 13, 2006 6:15 am
Thanks for the replys .I`ve got one but it looks non standard I thought it was another DPO mod
triumphelan
