Rear Diff
I'm planning my next project which will be an Elan destined to be used for hills and sprints. I have the basics already - a modsports shell and chassis.
Before I get too carried away with BHP and torque, it occurred to me that I should check some basics - so -
What is the maximum torque and BHP that my 4.1 diff could take before it goes pop. Is there a better alternative? Also is there a maximum for the rear suspension?
I do intend to run on slicks - what would be a good size (I was thinking around 10" but could take 12" in the wide arches I currently have.)
Gavin
Gavin
gav - Fourth Gear
gav wrote:What is the maximum torque and BHP that my 4.1 diff could take before it goes pop. Is there a better alternative?
I know its not 4.1 but in the latest Club Lotus mag there is a pic of a 4.428 diff with HUGE 31/7 teeth compared to a 4.44 40/9 teeth. Apparently they last a hell of a lot longer in competition!
I suspect they were on some commercial vehicle version of a Ford that used the English axle.
Martin
72 Sprint DHC
72 Sprint DHC
M100 - Fourth Gear
Gavin,
Give Tony Thompson at TTR or Pat Thomas at Kelvedon a ring, they will know what breaks and when!
Pete.
Pete.
Assuming you are still using a twin cam and capacity is less than a max bored long stroke block ( no 2.2 litre blocks or nitro) I dont think you will be able to break the diff itself. I still have my original diff in the car after more than 25 years of competition and many 5000 rpm drop the clutch starts with 170hp. It is the only original power transmission component in the car
For the rest of the rear suspension you need to reinforce the chassis around the diff mounts and A Frame mounts. Stronger diff output shafts, solid rear end with CV's or U/J conversion and stronger hub half shafts and steel wheel hubs also needed. Could also be sensible to use new A frames ( Spyder make stronger ones) as I have broken one of these also.
Thanks everyone for your help so far and if there is more info out there, I am still hungry for it.
I'm planning to use a modified Cosworth BD with a spec which is likely to produce between 225 and 240 BHP mut not that much torque. Is there anything else you would do with this in mind?
Gavin
Gavin
gav - Fourth Gear
Gavin
No experience with BD motors but torque is what sets the limt and a BD does not produce much more torque than an equivalent capacity twink, the extra power comes at higher revs due to better breathing from 4 valves. I suspect you will still be OK with the standard 4.1 diff.
But it and the prop shaft is probably all that you should keep in the powertrain.
I just broke an anglia van ,the diff was 4.44:1 , but definately 40/9,still unsure where the mystery strong diff comes from,will keep searching.Not that i've known many 'english' diffs break at all.
Martin
Martin
"He's not the messiah, he's a very naughty boy"
Monty Python's The Life Of Brian,best film ever.
- lotusanglia1965
