Diff brace mounting
Steve,
Scroll down about 1/4 of the way on this link.
http://www.rdent.com/pages/parts.html
Its two different pics of the brace and it'll be self explanatory when you receive it. It basically goes across the top of the diff, and fits only one way because it also picks up one of the diff housing bolt holes. You'll also eliminate one of the sets of washers used with the mounting bolts.
Greg Z
'72 Sprint
Greg Z
'72 Sprint
gjz30075 - Coveted Fifth Gear
It's worth fitting regardless of power output because it does offer a bit more support to the housing top mounting lugs which sadly do have a tendency to break off.
I agree with Greg fitting one is a doddle. You can't really get it wrong
... Steve, do not fit the brace to the diff before you install it- you will find it very much more difficult to get the diff into place if the brace is mounted. It is very easy to slip it into place once the diff is sitting in the chassis. Of course it is woth doing a trial fit before it goes in, it is really just a bit of "angle iron" with a bulge and a cut out with a boss welded on- you will need a longer than standard bolt to go through this boss, btw.
Pete.
Pete.
That explains why I struggled with mine
