Gearbox swop?
What a great bunch.. Sorted..
You guys efforts are super helpfull & Graham B gave me a good description of the pivot pin and with John's pic' and Brian's input they have helped clear it in my mind.
Andrew... I will if I may call down tomorrow. Will Late morning be ok? I will drop you an e mail asap to arrange.
Brian.. Thanks for the info' on the speedo Cable. I will get one made 6" longer.Thanks.
FYI... Graham Boulton told me that the Ford pivot pin is the part fitted into the top Hex part of the 5 speed assy....
Alex Black.
Now Sprintless!!
Now Sprintless!!
Hi Guys,
Graham Boulton is (as expected) exactly correct. I have just checked the Ford Pivot pin and it is exactly as per John's sketch.
Well done that man!
Just the bottom part to get then. If Brian sends me his spare I'm sorted... Graham said there was not one with the box so Sue is checking to see if she has one she can send with it. If I end up with two I will return Brian's... Or I could put it on Epay and drink the proceeds.
..... Only kidding!!
Alex...
Well done that man!
Alex...
Alex Black.
Now Sprintless!!
Now Sprintless!!
A lot of good info. here! I need both a bearing carrier and a bolt to carry the ford pivot [ hint AB!] One question, when assembling the propshaft is there an orientation regarding the uj yokes?
- AussieJohn
AussieJohn wrote:One question, when assembling the propshaft is there an orientation regarding the uj yokes?
John,
If you mean the orientation of the flange - then the answer is yes.
The holes in the gearbox flange are not equispaced on the PCD as per the diff flange.
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
bcmc33 - Coveted Fifth Gear
Hi Brian, I didn't really explain myself well, I was pondering on whether when you engaged the splines the yokes on either end of the propshaft had to have some sort of relationship with each other, cheers John.
- AussieJohn
Sorry to interrupt but I would say yes as it's a balanced item,hence the white paint marks on my prop.
Hi John, where are the paint marks? Or did you have it balanced and added your own?
- AussieJohn
AussieJohn wrote: Or did you have it balanced and added your own?
Yes - to your question.
My friend John is correct, and I'd thought I made some comment on it earlier.
The splines can go together in any position, but after balancing the shaft will need to be maintained in the same position to maintain the balance - hence the paint marks.
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
Aussiejohn
At the bottom of Page 9,top picture..
Thanks guys, I think I need stronger glasses!!! cheers, John.
- AussieJohn
All
There seem to be a few doing the five speed conversion this winter (hands up),in my mind it's a winner,better acceleration in first,being able to crawl in traffic (without slipping the clutch),and relaxed motorway cruising.
Will those who are, look at my picture,page 9 photo 3,and let me know if their gear lever is similar,if so,I'll pull mine out and take a photo of my solution to its position...
john.p.clegg wrote:Will those who are, look at my picture,page 9 photo 3,and let me know if their gear lever is similar,if so,I'll pull mine out and take a photo of my solution to its position...
It looks exactly like mine, John. I look forward to seeing the pictures.
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
Hi all,
Firstly,thanks to all who replied too my question,secondly,as I dont yet have a gear lever can anyone pass advice as to what to get ie standard or quick shift types,also,what oil to put in the box itself.
Many thanks,Paul
Many thanks,Paul
- pauljones
pauljones915 wrote:Hi all,
Many thanks,Paul
I Have the standard Ford gear lever, but plan to get a quick shift next time I go through Tamworth. That will give me the opportunity to make my own mind up as to which is best.
Redline MTL is the 'only' gearbox oil worth using. My opinion, of course.
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
