early vs late synchro hubs
rgh0 wrote:I would have to dig through my parts but i think I have a 1/2 syncro hub for an early gearbox. My last gear box build with Quaiffe gears was based on an old box and i could not use the 1/2 hub due to the differences with the later style shaft that Quaiffe supply.
Thanks Rohan that'd be great if you have something. when you say 1/2 synchro is that the inner section?
36/6612
1967 S3 Coupe (left the factory in 66)
original rego PPC 8E
original owner B.M. Wetherill ..are you out there?
dgym - Third Gear
dgym wrote:If the hub assembly is on Burton's page i must be blind or crazy!
the damage is: absolutely destroyed blocker bars and destroyed out outer hub section. It's unusable.
sorry my bad, I was somehow under the impression that you were looking for the brass synchros rings (early version being at times harder to source), then only considering a complete assembly swap if suitable rings ended being unavailable - I should have read more carefully... good luck !
S4SE 36/8198
nmauduit - Coveted Fifth Gear
