5 Speed gear lever problem.
PostPost by: dougal9887 » Sat Mar 21, 2015 11:51 pm
Well, having a replacement and useable lever, I could afford to try disassembly of my original lever.
Not to difficult as it turned out so I disassembled both and rebuild mine using just the cup washer from the replacement lever.
These pictures illustrate the procedure I used, and hope they may be of use to anyone needing to get one of these apart.
2015-03-21 17.22.15.jpg and
Replacement lever. Chrome rather marked and rubber boot split. If mine comes apart I'll just be using the cup washer from this one.
20150320_155832.jpg and
The anti vibration joint is secure by two punched tabs.
20150320_160215.jpg and
The tabs were drilled out.
2015-03-21 17.23.46.jpg and
The joint was then separated by rotating it with a stilson wrench whilst pulling apart. The wrench does mark the flared section of the joint but this is covered by the gaiter.
20150321_151824.jpg and
Voil?.
2015-03-21 17.18.41.jpg and
The bottom part of the lever was removed from the metal sleeved
rubber bush using a drift. The
remainder can then be dismantled. The new cuts seen in the upper lever are to allow securing tabs to be punched inwards.
2015-03-21 17.19.29.jpg and
Bottom part reassembled.
2015-03-21 17.20.18.jpg and
Top part was pressed back on using a valve spring compressor and just water as a lubricant.
2015-03-21 17.21.10.jpg and
Job done!
Dougal.
dougal9887
PostPost by: john.p.clegg » Sun Mar 22, 2015 6:55 am
Dougal
Nice one !
I don't have the anti-vibration fitting in mine,just a solid piece with a couple of grub screws to keep it in place,makes it easier to take apart,haven't noticed any vibration coming through,gives it slightly more "feel".
John :wink:
PostPost by: Spyder fan » Sun Mar 22, 2015 7:13 am
Dougal
That's excellent instructions and photos, there really should be an indexed "How To" archive section containing helpful posts like this.
Kindest regards
Alan Thomas
Spyder fan
Previous
