Differential removal
PostPost by: stugilmour » Tue Oct 08, 2013 5:47 pm
Thanks for the detailed reply Rohan. Kind of confirms my thinking.
Later Renault UN-1 is also spiral bevel diff. Interesting because have noted some confusion as original (NLA in NA) UN-1 lubricant (Castrol TAF-X) was listed as GL-5, and the Lotus recommended replacement is listed as 'GL-4+', which presumably is their own kind of made up spec indicating it exceeds GL-4 without a heck of a lot of phosphorus and/or sulfur. Anyway, thats what the Red Line tech representative indicated to me when I contacted him and he confirmed MT90.
Here is a link to a post I did up on Esprit lubricants with the various tech sheets.
http://www.lotustalk.com/forums/f164/wh ... il-117721/
Cheers!
Stu
1969 Plus 2 Federal LHD
PostPost by: umbyfer » Sun Jul 27, 2014 8:55 pm
Millers Oils has EP 80w90 GL4 and EP 90 GL5
Umberto Ferrari
Modena - Italy
Elan Sprint 7108000193K
Elite SII #1319
umbyfer
PostPost by: jk952 » Tue Jul 29, 2014 11:32 pm
I think I recall, once all disconnected as others stated, slide the diff back a bit (it can't go far!) and point the nose up and to the right side of the car and rotate the alloy casing end down and out on the left as stated. (Check for clearing brake lines and handbrake cables etc. so they don't snag depending where they lay.)
Note it weighs about 40 lb.
Jack
jk952
Previous
