Magnesium, Aluminium gearbox bits
Ed
I looked at the (5) 3/4 shift forks and they all have seen better days.
Ray has the shift forks for $90 and gasket sets $17
http://rdent.com
Shift Fork
Shift fork for 3rd/4th gears
Ref. 26F7230 - $90.00
Gearbox Gasket Sets
Ref. 26F0001 - $17.00
http://rdent.com
Shift Fork
Gearbox Gasket Sets
ok thanks ---Ill get a hold of them and solve the jump out of gear problem ---- should do 1 and 2 also --never having done the job before should be fun ----looks like it can all be done from the access cover once the motor is out and the tail shaft off ----ed
garyeanderson wrote:Ray has the shift forks for $90 and gasket sets $17
I bought a set of these forks from Ray a little over a year ago. They are fine but I needed to file a fair amount casting flash away from the bosses that the selector rods pass through. There was enough casting flash that the forks just touched each other in one position such that one gear was hard to select, I have forgotten which one. This was not a big deal because I checked all of the motions before I buttoned the box up. It would have been a big problem if I didn't check everything before putting the box back in the car. I mentioned this to Ray and he was going to work with his supplier to get the casting flash cleaned up. The fork in Gary's photo looks to be free of casting flash.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
Elan +2S (1971)
Elite S2 (1962)
Users browsing this forum: No registered users and 52 guests
