Checking Diff
Is there a way of checking the diff without stripping it down.
The diff in my car seemed fine when the car was taken off the road for the resto - no whining or vibration.
Having now removed the intermediate drive shafts I can feel some play in the diff output transmission shafts if I hold both shafts and turn forward and back.
Is this normal or do I need to have it checked by someone who knows about diffs
thanks in advance
thanks in advance
- Chris-72-Sprint
What you can feel is the backlash between the crownwheel and pinion gear teeth - this is quite normal. On assembly this is set to 5-7 thou.
If your diff was not noisy in operation I would leave well alone, a rebuild will be expensive and if not done properly you could end up worse off - if it aint broke..........
S4 DHC
S4 DHC
- oldelanman
Most of the backlash you feel at the output shafts is actually in the spider gears not the crown wheel and pinion.
Free play of a few millimetres at the ends of the output shaft donut coupling arms is normal.
If the diff was making no noise and not leaking I would leave it alone
Thanks v much for replies......thats a relief !!
regards
regards
- Chris-72-Sprint
