Elan +2 Roof Colour
PostPost by: Hamish Coutts » Fri Aug 20, 2004 8:10 am
My 1973 +2 Elan S130 is lagoon blue with a silver metaflake roof. The roof is needing repainted. Does anyone know the 'official' name for the roof colour?
I believe the paint work is original.
I've had a look at ther paint codes in mikecauser.org but I need to know the name of the paint to get the code number.
If this paint is no longer available, does anyone know an aquivalent?
Hamish. :)
Hamish Coutts
PostPost by: 1964 S1 » Fri Aug 20, 2004 1:05 pm
Here in the US I can go to the paint store and they've got a device that computer matches the original color. It's held up against the car or you can take in a paint chip and a match can be done. If there is a place on your roof that doesn't have the fade and this system is available to you I recommend it. Make sure the supplier is aware it is a fiberglass car so the proper type of paint is sold to you. If you cannot find the code this might be the answer.
1964 S1
PostPost by: nebogipfel » Fri Aug 20, 2004 6:22 pm
Hi Hamish,
Some paint factors in the UK have the device mentioned in the previous post.
I'm not sure it will help with a metalflake finish however. If your local factor stocks traditional metalflake they could probably advise you on how to get a similar colour.
Assuming they have flake available in the correct colour you will still have to make a judgement about how much flake to use to obtain the correct density.
Personally I wouldn't sweat it too much, just aim for a nice bright uniform flake finish. Also remember that if your roof is typical of some I have seen the original laquer will have mellowed and yellowed quite a bit over the years. At least modern 2K laquers resist yellowing much better.
Although I have had the pleasure of painting cars for a number of years I have never tried metalflake however I have seen a colleague use it and I recall that the technique is to put some ball bearings in your paint gun pot and remember to keep shaking to keep the flake in suspension!
nebogipfel
PostPost by: tinman » Sat Mar 12, 2005 6:09 pm
HI hamish
I repainted a +2 roof ayear or two ago,
i still have a bag of metaflake silver,
regards
tinman
tinman
New-tral
PostPost by: Hamish Coutts » Mon Mar 14, 2005 9:44 am
Tinman,
Could you e-mail me on [email protected]. I'm interested to hear about the bag of metaflake.
Hamish.
Hamish Coutts
Users browsing this forum: No registered users and 55 guests
