Engine bay undertray above rack - S3
Good evening.
It seems to be tricky to find photos of this area.
Does anyone have any photos showing how the glass fibre "undertray" (the lower part of the body mould) should look for a S3 car in the area above the steering rack / under the radiator please? I've seen references to a stiffening flange and also that the design was changed from the earlier cars, but mine has been hacked about.
Many thanks,
Will
Many thanks,
Will
- ill_will
According to Brian Buckland’s book, it was only s1 and s2 cars that had the radiator supported by the extended undertray over the rack.
Series 3/4 cars should, according to Buckland, have the radiator supported on metal brackets either side.
Here’s a photo of a photo which might help, copyright Brian Buckland.
- Lotusian
This is my Sprint, but is this the area you are talking about?
Note the lower body GRP does not go over the top of the rack, there is an extra part "Lower Radiator Shroud" to block airflow going under the radiator.
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
Users browsing this forum: wdb and 16 guests
