Fitting Badges S4 FHC
I had intended to leave the badge fitting to be the last job, but now as trimming is getting close I am concerned this may be an error.
Advice please,
Richard Hawkins
Advice please,
Richard Hawkins
- RichardHawkins
Rather than use the correct clips and plastic plugs for the boot lid letters and rear flank badges I drilled the holes, then using a round needle file adjusted the holes so that the pins were just a snug fit. A blob of silicone on the inside of the panel keeps the badges in place.
For the front badge (if it has threaded pins) I used rubber Rawlnuts (Well Nuts) rather than a nut and washer. You can tighten the Rawlnuts finger tight so that the rubber compresses and keeps the badge secure.
Also, before finally fitting the badges, give the paintwork around the badges a good wax polish. Then, when you come to polishing the whole car, you won't have to worry about getting polish right up to the edge of the badge, and the paint behind the badge is also protected.
1967 S3 FHC
1968 S4 FHC
1967 S3 FHC
1968 S4 FHC
- smo17003
Leslie,
Thanks, that is what I wanted to know. Basically I need to fit the badges before the car is trimmed, is that correct?
Now in response to your offer of front trunnion seals, how to proceed with payment?
Richard Hawkins
Richard Hawkins
- RichardHawkins
Users browsing this forum: DavidP and 22 guests
