Pedal Box Cross Shaft Bushes
I have been making progress on my +2. We were testing the new clutch master cylinder and slave yesterday morning and noticed quite a bit of play in the cross shaft that spans the pedal box. (FYI - we have an access hole in the top of the pedal box). It looks as though the bushes on each side of the pedal box are worn. I have been searching the forum for solutions for replacing the shaft bushes. I have seen several pedal box rebuild discussions but haven't found any specific bushes yet. Any suggestions for replacements? - thanks, Kevin
Kevin
1972 Elan +2 S130
1972 Elan +2 S130
- Cinbearcat83
The pedal shaft runs directly in the bosses on the pedal box. Options seem to be drill out a bit further and fit a larger shaft or have bushes made up.
- mikealdren
Did the same with the pedal box in my Plus2. In addition, mounted a .060" 4130 plate beneath the box in the footwell. The fiber glass in the top of the footwell was too thin, allowing the whole assembly to flex. Solved the problem completely.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
Thanks for the responses. It confirmed my suspicion that there is no "off-the-shelf" bush replacement for this. Good suggestions - Thanks, Keivn
Kevin
1972 Elan +2 S130
1972 Elan +2 S130
- Cinbearcat83
Drilled the shaft, nearly all the way, fitted a 90 degree grease nipple , allowed one to grease in-situ.
Good suggestions - thank you, Kevin
Kevin
1972 Elan +2 S130
1972 Elan +2 S130
- Cinbearcat83
