1966 Lotus Elan S2 - Windshield not fitting in frame
Looking for advice on how to install a new windshield into the frame of my 1966 Elan S2.. My body shop person is telling me that the contour is not the same. The windshield is the only one available and was made in England for the S2. I have the proper seal and locking strip. Please let me know if you have successfully installed one. Any advice that would be helpful. Thank you so much!
- gerard 22
Who is the supplier?...and who is the manufacturer?
Have you talked to whoever supplied it about the problem?
If the contour does not seem correct I would ask for it to be exchanged or at least somehow compare it with another one from the same source to check if there is a difference.
Alan.
Alan.
'71 +2 S130/ 5speed Type9.
- alanr
Are you sure of your supplied windscreen? Are you sure the screen is not for a S3 or S4? I don't believe they are interchangeable..
But that said, we had a terrible time installing the screen that had been in my coupe for most of it's life in 2021 after a complete strip and repaint and using new rubber . We could not get the old metal corner trims into the corners of the rubber.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
Thank you for you responses. The windscreen was made by Pilkington in England and it is definately for the S2. I will search for the posts from last year. I'm interested to know how the frame was adjusted to accommodate the glass. I'm in Los Angeles and looking for glass installers who have Lotus Elan S2 experience.
Gerard
Elan S2
Gerard
Elan S2
- gerard 22
I fitted the original windscreen back into my S4 so I know it's the right one but you would think it wasn't with all the trouble I had getting it in. It really did look like it wouldn't fit until the last bit popped in. Can you get someone to help you hold it in the aperture without the seal to see if the curvature looks right?
1969 Elan S4 FHC, purchased in 1978, now with a big valve engine.
- JohnMorin
gerard 22 wrote:Thank you for you responses. The windscreen was made by Pilkington in England and it is definately for the S2. I will search for the posts from last year. I'm interested to know how the frame was adjusted to accommodate the glass. I'm in Los Angeles and looking for glass installers who have Lotus Elan S2 experience.
Gerard
Elan S2
The gents I would trust to fit a windscreen are in Rancho Cucamonga, Frank Monise Motors. They have been working on Lotus since the early '60's.
Their contact info:
Frank Monise Jr.
[email protected]
(909) 608-1600
8800 Onyx Ave. #C Rancho Cucamonga Rancho Cucamonga, CA 91763
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
S4 SE
S2 GTS
Caterham 420R
661 - Coveted Fifth Gear
While on the subject, years ago Gary Anderson warned us that in USA anyone wanting a windscreen for a S2 should order one for a S1, because the S2 screen sold in American only fitted the coupe (FHC). That isn't applicable in this instance unless the same confusion has now reached Europe.
Meg
Quart Meg Miles wrote:While on the subject, years ago Gary Anderson warned us that in USA anyone wanting a windscreen for a S2 should order one for a S1, because the S2 screen sold in American only fitted the coupe (FHC). That isn't applicable in this instance unless the same confusion has now reached Europe.
vstibbard wrote:S2 coupe or dhc? If dhc the S1 and s2 screens are identical.
Vaughan
I should have said the S2 DHC (roadster) screen was the same as the S1. I assume the S2 and S3 FHC (coupes) shared a screen type and only differed in internal trim (and badges). What the S3 DHC uses I have no idea.
Meg
