Cabin to boot separation panel
Has anyone considered or tried fitting a panel between the cabin and the boot cavity on the Plus 2? I've had a search through the forum but found nothing.
With the amount of modern materials out there something could possibly be achieved with aluminium or plastic sheets?
Reading about the stories of fumes and noise, a panel, coupled with the others modifications, could perhaps achieve a good result.
An idea is to fit a panel behind the seat and also one under the parcel tray. The boot brace and strut brace can potentially be utilised for fitment. If anyone has achieved this I'd be very interested in some pictures.
- Bud5000
elanfan1 - Coveted Fifth Gear
I did do something similar on my Sprint.
I replaced the pressed fibre board rear bulk head with a panel made from sheet aluminium about 2mm thick.. The reason being it put some metal between me and the fuel tank.
Its worked OK for several years, but if I was doing it again I would look for a modern composite board with more thickness as the aluminium sheet seems a bit thin and flexes a bit.
Clive
Clive
1972 Elan Sprint FHC
- cliveyboy
I opened the PDF and I think that's the board that goes between the fuel tank and the boot cavity. I could be wrong as I don't have any boards like that in mine.
I'm thinking, as cliveyboy has done, of manufacturing some thing that attaches behind the rear seat and is between the seat and tank. Then another board or sheet that is above the fuel tank but directly under the parcel tray.
I think there's enough bracing that could be somewhat adapted or modified with brackets to attach the sheets too. It's then a matter of strategically using foam or rubber to cushion and support, as well as reduce noise and fumes.
Can mock something up with cardboard to test out the feasibility.
If it looks like working I'll document it in the forum for all to see.
- Bud5000
There are already panels, the rear seat back and the parcel shelf. What do you want to achieve by adding duplicates?
If its reduce fumes you'd be better addressing the source of the fumes (fuel tank plumbing or boot seal), than try to fit new panels and get them air tight.
- mbell
What sort of fumes? Fuel fumes?...Exhaust fumes? Either of these could have potentially serious consequences.
Your +2 should not be creating any fumes that are entering the cabin area. My thoughts are that you need to to track down the source and why this is happening.
'71 +2 S130/ 5speed Type9.
- alanr
Totally right on all accounts guys, any fumes should be eliminated at the source. I've read about the fuel filler problems and tank sloshing so will do the fuel breather modification.
Honestly I've only had it 2 months and driven it a few short kilometres before parking up due to having surgery. (Lots of forum reading during recovery) So any actual noise and fumes are mostly unknown at this stage. It's only what I've read from others experience and I'm just writing out loud I guess.
I'm hoping to try and make it a nicer driving experience by updating some of the technology without losing too much of the ethstetics. I figure if a modern chassis and motor can be used then a couple of extra panels won't hurt. All just speculation and thinking out loud so far, but happy to play around with it.
It's my first Lotus and after 60 days I've gotta say I see why everyone loves them.
- Bud5000
There are two modifications that you need to do to get rid of fuel smells both in the car and in your garage.
One is the original Club Lotus fuel mod which eliminates the original large fuel breather pipes that crossover above the rear interior headlining and the other mod is to fit a Mazda MX5 ( Miata) plastic anti-sloshing one-way valve in the actual fuel filler pipe.This stops the fuel backing up the filler pipe and sloshing out of the filler cap seal/vent.
My car when I bought it really stunk my garage out with fuel smells..really bad. I did both mods and completely eliminated any smell of fuel either in the garage or when driving the car.
Alan.
Alan.
- alanr
My plus 2 is an ex race car and has the boot area fibreglassed off from the fuel tank. Something to do with regulations. I can take some pictures at the weekend if it helps......
Berni
Berni
berni29 - Fourth Gear
I only saw your original post today.
Coincidently I posted regarding this matter in "Plus 2 discussions" "Boot bulkhead" yesterday evening.
The 2mm aluminium sheeting is attached directly to the body fibreglass, and does not interfere with the rear tower brace or the boot brace. A 1" flange on the front of the parcel shelf panel overlaps and is screwed to the top of the vertical panel.
The tower brace sits directly up against the vertical sheet. The parcel shelf trim panel is secured on the original tabs on the tower brace.
68 Elan +2, 70 Elan +2s
Foxie - Coveted Fifth Gear
