RESINE ISO or ORTHO
What resine are you boys using.
I'm only using ISO Marine quality now.
I was supplied with ORTHO and found it no good for me, the surface stays tacky
- alan.barker
I have been doing repairs to some cracks using Miles Wilkins method as i have always done. Resin, matt, tissue only no P40 filler with fibres.
But the last Tin of Resin i bought was identified as "Ortho" and it leaves a sticky surface which i don't like.
I will return to the shop and change it for "Iso Marine grade" which i prefer and it doesn't leave a sticky surface.
I would like to know if others have sucess with the "Ortho" resin.
So do you boys prefer "Iso" or "Ortho".
- alan.barker
I use East Coast Fibreglass Supplies general purpose polyester resin
https://www.ecfibreglasssupplies.co.uk/resins
I note it is an ortho resin. I hadn't even considered that before as it just seems to work. Stimulated by your thread to read more, I note the 'Lloyd's approved' resin appears to be a different spec.
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
S4 SE
S2 GTS
Caterham 420R
661 - Coveted Fifth Gear
Great we're all learning.
I understand that "Ortho" is the cheap one and not the strongest(stays sticky).
I understand "Iso" is stronger and resists better against water/dampness.
The one i'm not using which is the strongest of all is "Epoxy".
I prefer to use resin not too different so they flex together in harmony but that's my personal idea.
- alan.barker
Ok i'll mix some "Ortho" with new MEK on my wetting out board and see if it dries sticky.
- alan.barker
alan.barker wrote:Ok i'll mix some "Ortho" with new MEK on my wetting out board and see if it dries sticky.
I know it's obvious, but I'll mention it anyway, it's worth using 1 ml syringes to get the hardener amounts right. Check the manufacturers recommendations, I use 2% with the East Coast stuff
Graeme
S4 SE
S2 GTS
Caterham 420R
S4 SE
S2 GTS
Caterham 420R
hi Graeme,
yes a good reminder and that's what is marked on my tins 2%
- alan.barker
Just bought "ISO MARINE" Resine which should dry with "dry" surface which is needed for finishing.
ORTHO dries with tacky surface which is ok if you laminate ontop. I think a trick with ORTHO is to cover with Clingfilm to get it to harden with "non tacky surface" .
Easier to buy "ISO MARINE" .
PERSONAL CHOICE.
PERSONAL CHOICE.
- alan.barker
My understanding is that Ortho is deigned for mould use where it has an airtight outer edge, for example in the tissue layer. ISO is for later and final layers which are in contact with the air. I may, of course, be entirely wrong!
- mikealdren
Thanks Mike that confirms what i think.
If Ortho used on outside surface you need to cover with Clingfilm or something.
- alan.barker
