Heated Rear windscreen
1967/68 Plus 2 and I have the blue light on the dash and the words Rear screen. I don't know what the rear window heater would look like. Is it the traditional stick on style with the lines that go across the screen? If so my window doesn't have that. So can I assume that I have the light but no heater? Was the light on the dash fitted regardless of having the heater or not? I've decoded the window data and it should still be the original window, unless it was replaced very soon after production. Can anyone enlighten me to why I have the light?
- Bud5000
Cheers for the photo, pretty much what I thought.
The rear screen dash light does have wires attached but I've yet to trace them. There's no switch that I can see unless it's the bank of unnamed switches by my right knee.
Possibly the whole wiring system was fitted and the rear screen was replaced very early in its life?
Only bought the car 2 months ago so it's all new ground.
- Bud5000
The early +2 heated rear screens had the elements going up and down vertically. The more usual horizontal elements appeared around a year or so after production began.
I have a feeling that heated rear screens were an option on early cars, but I’m away currently so unable to check my data.
Visit www.lotuselansprint.com
trw99 - Coveted Fifth Gear
In the 1970 Plus 2 UK price list the rear heated glass is optional. Could be either a stand alone option or in combination with window tint.
The 1970 Canadian price list did not show the heated rear glass as either an option or a highlighted standard feature. My 1969 Canadian Federal model had the labelled dash switch and light, but no rear element. I don’t recall if the wiring was in the loom, but thinking not. I suspect this is how it worked if the option was not specifically ordered, but not sure.
When I had my new dash made, I specified leaving the labelling off the switch and light. Ended up repurposing them for added driving lamps; my Federal pre-dated the Lucas Square 8 lights than came on the later S models over here.
Have found that the rear defrost is not really necessary. In my experience just running with the windows partially open for a few minutes generally removes any frost on the rear glass.
HTH. Will be interesting to see what others have found.
Stu
1969 Plus 2 Federal LHD
trw99 wrote:The early +2 heated rear screens had the elements going up and down vertically. The more usual horizontal elements appeared around a year or so after production began.
I think the wiring was put in even if the rear window had no heater built in.
I can just see the technicians on the Lotus assembly line now...
"Hey did you fit the heated rear screen?"
"Ya know I'm not sure"
"Ah she'll be right, no one will ever question why there's wires and no heated screen"
Awesome thanks everyone. I'll most likely just repurpose the hole for something else and delete the rear screen dash light.
- Bud5000
