Federal S4 Boot Hinge Brace
PostPost by: 0005K » Tue Jun 27, 2023 3:49 pm
I have 2 right angle tabs on the bottom of my Federal S4 DHC boot hinge brace. They appear to line up with the fuel tank straps. Do they hook under the straps or fit above the straps? Do I add a short piece of heater hose or foam over the tabs to soften the contact?
Dick
IMG_0486(1).jpg and
0005K
PostPost by: gjz30075 » Tue Jun 27, 2023 11:40 pm
The fuel tank shouldn't have straps. There are simply three studs protruding from the bottom of the
tank through the body. Do the tabs line up with the hinge locations?
I just realized maybe you're referring to the extra tank that sits in the void between the strut
towers, that some cars received. If so, is that tank held in by straps? Can you provide a picture?
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: 0005K » Wed Jun 28, 2023 7:11 pm
The primary tank on my Federal S4 is not on the floor of the boot, but is located between the rear strut towers and is attached with two straps. A smaller tank is attached to the left.
IMG_0496(1).jpg and
0005K
Users browsing this forum: Dan in NJ, Matt Elan and 10 guests
