Flat spire fastener
Nor sure what these things are called but they look like half a spire clip. Used extensively to fasten things through the bodywork using self tapping screws which engage with a shaped hole in the (whatever it’s called). It’s a flat bit of metal, about 15mm x 7mm made of springy steel.
I’m going to need some (lots) but haven’t found a supplier. Any ideas?
JonB - Coveted Fifth Gear
Piccies of the little mcguffins.
Mazzini - Coveted Fifth Gear
Thanks Mazzini
A bit expensive. Must be a Spalding Fasteners “thing”.
Meanwhile I found this
https://www.bresco.com/acatalog/Rectang ... tml#SID=17
Just got to work out the required size and I should be well away. £10 for 30 plus vat and shipping.
