Windscreen sag S4
Another body related question.
Got the body off the subframe and sitting on a pallet. Noticed the windscreen is sagging a little. It's evident in the shutline of the window frames, which closes up as you get closer to the top of the frame. The frame itself has some play in it and this appears to be due to the screen rubbers perishing and shrinking. So, when I replace them, I should expect an improvement?
Other thing is the little wire support in the middle of the screen, meant to strengthen the frame. It's a bit loose. Should it pull on the header rail so as to hold it down, or push so as to hold it up?
JonB - Coveted Fifth Gear
Hi Jon
The tie bar to the top of the windscreen frame is to hold the frame against the pull of a tensioned hood.
without it the hood would pull the rather flimsy frame top away from the glass.
Eric in Burnley
1967 S3SE DHC
Eric in Burnley
1967 S3SE DHC
- ericbushby
JonB wrote:Another body related question.
Hi Jon
I had a similar problem with my Sprint in that the top of the window frames rubbed the top of the windscreen frame. On investigation the windscreen frame felt quite loose/flexible. There are meant to be a pair of rebar brackets strengthening the joint between the bottom of the windscreen frame to the top of the scuttle. They were not there on my car. It seems my car started life as a FHC but was poorly converted to a DHC early in it's life and the strengthening brackets were not fitted. Having fitted them the windscreen frame is much more rigid.
Maybe worth checking if yours are there.
72 Sprint DHC
72 Sprint DHC
lotusfan - Third Gear
Users browsing this forum: rideaway and 20 guests
