Anatomy question
PostPost by: steve lyle » Thu Mar 30, 2023 10:57 pm
I've disassembled the car to fix things that need fixing and to respray it.
When I got the car, the block that is the fixing point for the upper end of the windscreen tension rod was not attached to anything - it was just floating, within the vinyl trim. No machine screw.
So now I want to fix it correctly. So the questions are:
- What type of head should the screw have?
- Does the screw head sit atop the aluminum hood retaining strip, or underneath it?
-- If atop, I assume there's some sort of spacer between the top rail and the retaining strip. What are the dimensions of that spacer.
IMG_0028.JPG and
Steve Lyle
2007 BMW 335i Coupe
steve lyle
PostPost by: Ianstuart » Fri Mar 31, 2023 12:39 pm
Slotted stainless cheese-headed screw on top of aluminium strip, 10mm dia x 5mm spacer below.
Here’s mine
D80948C2-ED5F-4C02-92D3-21D7EC3A8BEB.jpeg and
633A9305-80C4-4B7F-BDE5-5EEB98338366.jpeg and
Ianstuart
First Gear
First Gear
PostPost by: steve lyle » Fri Mar 31, 2023 3:28 pm
Thank you!
Steve Lyle
2007 BMW 335i Coupe
steve lyle
Users browsing this forum: No registered users and 45 guests
