RHD Handbrake cable length
I'm converting a LHD handbrake cable to fit in a RHD car.
Does anyone know the amount to cut off of the wire?
Should it be cut from the back or front end? A dimension from the outside of the swage fitting would be a great help. I reckon about 2"?
I'm using a local sailboat rigging shop to swage a new fitting on.
Joseph
Joseph
skyarch - Second Gear
I'm reasonably confident that LHD and RHD handbrake cables are the same part number / length. Have you checked the parts manual to see if there are two?
The minor routing difference - diagonally across or straight down the chassis backbone - can be accommodated in the adjuster.
Nick
Nick
elanner - Fourth Gear
Hi Nick,
Maybe the original had different numbers? I got this from Ray.
It's routed correctly and it has slack in it even with the adjusters maxed out.
There's a whole topic on this on the Forum, I've spoke to Sue about a new one but I'm still waiting.
So in the meantime I have the cable that was on the car when I got it and I'll have that cut.
The P.O. had a cable adjuster installed between the front adjuster and where the cable enters the tunnel, see the attached photo.
- Attachments
- b43e362e-25b2-422e-8dfe-048366ada1a3_1.8642bef09b3f01e07e60ccec89ecf0cb.jpeg (6.17 KiB) Viewed 465 times
Is the swivel at the back turned fully back.
Also the tie rods to the calipers.
Some owners have fitted adjustible tie rods.
- alan.barker
