Inertia reel safety belts
PostPost by: TBG » Tue Feb 21, 2023 12:10 pm
Another small annoying thing that I expect one of you will have the answer. Both my original? inertia reel belts hesitate a lot when pulling them out. Is there a quick and easy way of stopping this happening? D
TBG
PostPost by: trw99 » Tue Feb 21, 2023 3:13 pm
David, this was the only helpful info I could find after a quick search. It may be help?
"If you tap the reel gently with a hammer it can free the mechanism. I cleaned out any dirt and fluff I found then sprayed some WD40 into the mechanism; worked the belt back and forth till it became free. It's been OK ever since."
Inertia reel seat belts were a factory option for a while during Series 3 production, but you don't see many. Are they Britax or Kangol, or some other make?
PostPost by: TBG » Tue Feb 21, 2023 3:56 pm
Tim - they have no makers mark! Getting at the works is proving a struggle - the end cap is recalcitrant! D
TBG
PostPost by: prezoom » Tue Feb 21, 2023 4:05 pm
The belts in my Plus2 utilize a swinging pendulum to lock the belt from moving. If the car is sitting on an angle, the belts will lock and can no longer be pulled out or adjusted when trying to fasten them. Moving the car to a level position, and everything works fine. This can be rather annoying.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
prezoom
PostPost by: pharriso » Tue Feb 21, 2023 4:17 pm
TBG wrote:Tim - they have no makers mark! Getting at the works is proving a struggle - the end cap is recalcitrant! D
Can you post a picture? it will help in identifying the seat belts
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: TBG » Wed Feb 22, 2023 12:11 pm
Here it is. D PS - anyone know if they should be lubricated and if so how? I cannot get the end cap off but thought if I drilled a small hole I could fire in some 3 in 1 oil.
Safety belt.01.jpg and
TBG
PostPost by: pharriso » Wed Feb 22, 2023 4:56 pm
David I do not recognize you belts, they are definitely not the Kangol Reflex inertia belt used in US Sprints etc.
KangolReflex5.jpg and
Phil Harrison
PostPost by: Mazzini » Wed Feb 22, 2023 5:07 pm
S3 S/E's had Teleflex belts, but they weren't safe when new and less so now; the receiver was made out of plastic and over the years they become brittle and crack very easily.
PostPost by: TBG » Wed Feb 22, 2023 5:16 pm
Mazzers - mine are all steel. D
TBG
PostPost by: Mazzini » Wed Feb 22, 2023 5:48 pm
D! Where are you off to this coming summer? I'll be in France and Italy in June. I know Classic Le Mans isn't your thing, but lets see if our itineraries can be made to cross.
PostPost by: The Veg » Fri Feb 24, 2023 9:20 pm
If it were me I'd install new belts since the webbing is probably a bit degraded due to being half a century old.
2012 BMW R1200GS
The Veg
PostPost by: TBG » Fri Feb 24, 2023 10:35 pm
Mazzers! Northern Spain first fortnight in June..................D
TBG
PostPost by: Mazzini » Fri Feb 24, 2023 11:19 pm
B***er! Off to Matera and Lecce - starting early June and coming back after Classic Le Mans.
PostPost by: Bud English » Sat Feb 25, 2023 5:46 pm
You do know that there is a Private Message button, don't you? Or, are you picking up retractable seat belts while on vacation/holiday? :roll:
Bud
1970 +2S Fed 0053N
Bud English
PostPost by: TBG » Sat Feb 25, 2023 11:11 pm
Winnemucca - says it all really!! D
TBG
Users browsing this forum: mar083 and 20 guests
