Tenax Studs at rear of soft top
PostPost by: mark030358 » Wed Feb 08, 2023 4:35 pm
Has anyone got any photos of the original tenax studs and washers used at the rear of the soft top. If possible can you give me the thread length.
Actually were there any washers under the tenax stud?
PostPost by: ericbushby » Wed Feb 08, 2023 5:02 pm
Hi Mark,
I can`t get a photo today, but the stud comes with it`s own shaped washer 15mm diameter. The remaining thread length of mine is 15mm with the washer fitted. Mine are not original but look OK.
Hope this helps,
Eric in Burnley
1967 S3SE DHC
PostPost by: richardcox_lotus » Wed Feb 08, 2023 5:03 pm
No measurements just yet but the nuts that are used in the location where you also capture the hood ( I.e. the middle 5 or 6) are a little longer. And I have thin brass washers each side.
'72 Sprint
Users browsing this forum: No registered users and 46 guests
