Nuts and bolts
PostPost by: Huntd105 » Sun Dec 04, 2022 7:56 pm
Hello everyone,.
Im Dan Hunt. I have recently come into ownership of my granddads 1971 sprint. Sadly its in pieces. So heres my question.
Ive gone through the boxes, pags, draws, everything and it seems every part is there except nuts and bolts.
Im aware the elan will be imperial. Just not sure what size or thread types.
Im looking to. Put in a parts order and need an idea of where to start.
Thanks in advance!.
Dan,
Huntd105
New-tral
PostPost by: SENC » Mon Dec 05, 2022 2:23 am
Buckland's book has a pretty good list, as I recall. If you don't have one, they're available again and, in my opinion, quite valuable alongside the shop manual.
Henry
69 Elan S4
65 Seven S2
PostPost by: stugilmour » Mon Dec 05, 2022 3:10 am
Welcome to the forum Dan.
Many of the Elan fasteners can be “decoded” from their Lotus part number. The Wiki has an introduction to how it works, but if the fastener follows the system you can get the size and thread type for most everything that is common.
https://lotuselan.net/wiki/Intro_-_Stan ... ber_Coding
HTH
Stu
1969 Plus 2 Federal LHD
PostPost by: StressCraxx » Mon Dec 05, 2022 5:37 am
Welcome Dan,
If you can find an original parts manual, they have almost every fastener you can think of and a decoder of the part numbers. In addition, the exploded diagrams are excellent for disassembly and reassembly, even better than the manual.
Congratulations on your Sprint, you grandfather had excellent taste.
Best regards,
Dan Wise
StressCraxx
PostPost by: Huntd105 » Mon Dec 05, 2022 6:47 am
Thank you thank you everyone. Il start writing out a list today of everything i need to bolt on doors, bonnet, boot, seat runners, to get the car ready for transport.
The car itself had a restoration started some 25 to 30 maybe more years ago. So far it looks that drivetrain, brakes, suspension are complete. But im mentally prepared for the possibility that it may all need stripping down again. As it seems a bit seized up
Dan,
Huntd105
New-tral
PostPost by: alan.barker » Mon Dec 05, 2022 7:23 am
Super project,
I suggest you try to split jobs.
E.g. rolling chassis first with the suspension. Next brakes and brakes lines.
After Engine Gearbox and Diff.
Not too many things at same time.
Good luck
