Grey underside paint
I think you’re referring to the gel coat which is the base layer over which the GF mat is laid. It’s not painted on but the colour of outer layer of the body applied during build. If you clean off all the crap you should find it’s still there.
Where I have repaired this gel coat on the underside I have used Hammerite Smooth mixed to the correct grey colour using black and white paints. Just be careful to measure and record the mix to get the same shade each time.
Elan +2
Elise mk 1
Elise mk 1
- Donels
I am painting underside and inside of my +2 shell with a paint called Gravitex. Well worth checking out I think.
All the best
Berni
All the best
Berni
berni29 - Fourth Gear
Well this took a while..
Underside cleaned and stripped to gel coat (where it remained), old repairs made good (I’m still itchy) and coated in 2 part epoxy primer (amazing adhesion) and the 2part epoxy gloss.
Still some way to go with the gloss but getting there..
Giff - First Gear
