Rear interior trim panel to side panel picture
PostPost by: snowyelan » Sat Jun 11, 2022 1:06 pm
Hi All,
Can anyone supply a picture of the side to rear panel, specifically where the lower seatbelt passes thru? From dry fitting it appears the seatbelt bracket is buried behind the rear panel? This is for a S4 DHC.
Scott
45/9011
Hawkestone, On, Ca
snowyelan
PostPost by: snowyelan » Mon Jun 13, 2022 11:40 am
After searcing for a few hours I found the pic below from a rollbar equipped S3 with inertia belts in Tom Jones rebuild thread.
Can anyone confirm that a S4 with fixed belts is the same? I question it because the belt length adjustment is at the lower outboard bracket and it seems odd that the adjustment would be buried behind the panel.
Scott
45/9011
Hawkestone, On, Ca
snowyelan
PostPost by: pharriso » Mon Jun 13, 2022 4:23 pm
snowyelan wrote: Can anyone confirm that a S4 with fixed belts is the same? I question it because the belt length adjustment is at the lower outboard bracket and it seems odd that the adjustment would be buried behind the panel.
I have a Sprint with Inertial belts, but I can confirm that the outer rear anchor is behind the rear panel & the belt simply passes between the rear panel & the side panel as shown on your picture.
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: snowyelan » Mon Jun 13, 2022 4:35 pm
Thanks Phil. I'll proceed with putting the panel in. I guess seatbelt adjustment lands in the same difficulty category as fuel pump removal.
Scott
45/9011
Hawkestone, On, Ca
snowyelan
