Lock barrel disassemble?
Has anyone managed to take apart the lock barrel? Originally made by Wimot Breeden, replacements are currently made by Weston Body Hardware. I feel this must be possible, but I am currently defeated. Alternatively does anyone know of a company who can do this for me?
Richard Hawkins
Richard Hawkins
- RichardHawkins
Try Morelands Locks.
Visit www.lotuselansprint.com
trw99 - Coveted Fifth Gear
Arun Locks provide a good service for all classic car lock types and will supply any lock barrel with correct wards to suit your key number and will also supply the key if required. I ran my Cooper for years with different keys for ignition, doors and boot but Ian supplied new barrels to match the ignition key FS number. You can faff around filing the wards to get them to match your key, I have tried, but it's not worth the bother.
Contact Ian Rands
07598 805533
01403 786213
[email protected]
https://www.arun-locks.co.uk/
Contact Ian Rands
07598 805533
01403 786213
[email protected]
- 111Robin
On the side of the barrel is a strip of stainless steel say 5mm x20mm in size held in place by the alloy barrel being peened over. This strip will slide out with a small screwdriver....be careful and do one at a time because each hole uncovered has a spring and two pins so keep in order. I think it is 5 sets.Now the centre barrel will turn and can be removed by looking at the opposite end to the keyhole and with pliiers squeeze the brass ring until it comes out of a groove in the end of the centre barrel .
Any key can be made to fit by inserting into the centre barrel and choose or file pins to sit flush with the barrel outer surface.The second set of pins can be of any length in assembly and all the springs are the same.
When you have lost the bits buy a new unit from a Triumph TR6 or GT6
Tony
Tony
- 10kph
Thanks everyone I think this information will get me sorted.
Richard Hawkins
Richard Hawkins
- RichardHawkins
