Sandi68S4 GRP Project
Starting a new thread to hold all questions for you all regarding the work to get the body parts repaired. See https://lotuselan.net/forums/viewtopic.php?f=36&t=50917 for front image thread.
Next on the list is this area in the boot. A PO had a rotoflex separate which caused this damage. There is a repair but the contours were not made and the bracket for the spare tyre cover is absent.
1. What’s the approximate size/position of this piece? Is it a screw-down for the plywood?
2. I believe it’s sandwiched in between the 3-4 layers of mat there?
Any assistance, with images if possible, is appreciated.
Jim
Jim
- Backmarker
there would be a pin catch to hold the plywood floor in that area (pin attached to the underneath of the floor), matching the height of the spare wheel (and the tank, more or less...)
e.g. see https://lotuselan.net/forums/viewtopic.php?f=36&t=24368&start=
S4SE 36/8198
nmauduit - Coveted Fifth Gear
The bracket for the boot board is a simple piece of angle with a spring clip to receive the ball pin on the board. The bracket is riveted or screwed to the front trunk wall just below the ledge. I'll see if I can find a photo.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
Thanks for the assist. The thread reference has an image, with drawings of the three boot pieces.
Jim
Jim
- Backmarker
Jim,
How would you like a 3 D model, or an actual Elan to touch and see how it needs to be fixed?
I have both my Elans on the other side of the state, just north of Daytona, if you'd like to see how its supposed to be.
PM me and we'll see what can be done.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
