Cant rails stowage strap??
If you locate a member on here who goes by the name of quart meg miles?
He has the original brackets / fixings in the boot of his S1 .
I bought a pair of cant rails off him at Goodwood several years ago and he showed me how and where the cant rails were stored within his very original S1 .
I need a pair of these fixings also , any body reproducing them ?
- greg40green
The other end of the strap clamps under the HOOD RAIL CATCH bolts on the other side. They're the small pair of bolts on the right over a little bracket which traps the strap. [Edited Meg]
I cut my strap off as I had never stored my cant rails, or anything else, under it and it was in the way..
I tuck the rails where the rolled-up hood is supposed to be above the rear lamps with the vertical elements lying in the spaces behind the wheel arches. But I don't think you can do that if you still have the rain guides attached, which I don't. I have rain gullies stitched in to my hood and the hood behind the side window wraps round and clips to the cant rails by Velcro.
Meg
This post is just to notify that the above post has been edited dramatically!
Meg
Thank you Meg.
I notice that you have a antenna going through what I wondered was a factory antenna hole. At least that is where I had a hole that I filled.
I wonder if that system worked that well to hold the cant rails anyway. I have the large cup that is supplied with the top rail hooks already fitted and might not bother making up that bracket.
Kurt
26/3754
Kurt
26/3754
- nomad
I agree with Kurt, it was a rubberised strap used on upholstery. I don.t know whether it was supposed to be tight or loose, some original owners might remember, and as I never had an owner's handbook I didn't know what it was for.
The aerial was already fitted when I bought the car. I'm tired of it whistling at high speeds and want to take it off but it's a big sunken pit under the aerial (or is it a raised dome) with cracked paint and glass so needs a wide cover.or proper glassing.
What's the modern equivalent of Cirrus White paint in the UK?
Meg
